Ansys Learning Forum Forums Discuss Simulation General Mechanical Minimum Density Factor in Autodyn Not working Reply To: Minimum Density Factor in Autodyn Not working
Chris Quan
The Minimum Density Factor is used to limit the transport of extremely small amount of mass. It is not used to limit the amount of mass in an Euler element in Autodyn.
The default value of the Minimum Density Factor is 1E-4. Thus if the amount of mass being transported from one element to another element is less than the Minimum Density Factor x Reference Density of a material, Autodyn will not transport this amount of mass. It will transport the mass in next cycle or cycles (time step) when the mass being transported exceeds the Minimum Density Factor x Reference Density.
The proper use of Minimum Density Factor can help to prevent the error and warning messages such as energy balance error and time step too small.
