Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Installation 404 › Reply To: Installation 404
Hi Michael,
It looks like the default TCP port 8080 is probably being blocked somehow on your network. If the you are able to identify a port number that is not reserved by any other application running on your network, you can direct the installer to use that port number for logging in. For example, if you have TCP port 50000 open on your network, yoy could use the following command line to login by communicating over that port(If needed, get help from your IT.):
"AnsysInstaller.exe" -login_port 50000
May I know from AnsysInstaller which package would you be using? If it's only 1 single package then you can download packages from primary packages section.
