Ansys Learning Forum Forums Discuss Simulation Fluids Heat transfer between material solar panel Reply To: Heat transfer between material solar panel
timothysatriya
i forget to mention if my model use solidification and melting turn on and around geometry wall is adiabatic. for method im use hybrid and for time is transient. another setting is same from method explain from that journal
