Ansys Learning Forum Forums Discuss Simulation Fluids Connection Stiffness Ansys AQWA Reply To: Connection Stiffness Ansys AQWA
S.S.S.ShankaVasuki
Thank you for your reply. I shall try running the simulation again. But I just had a last question.
  1. In the research paper I am trying to validate, they mention – “for the motions of roll and pitch, the viscous damping coefficient of the bodies is set as 5% of critical damping”. So I just wanted to know what does this signifiy and where should I enter this value? and how do I calculate the value of critical damping?
Link to the paper: A method to Estimate Dynamic Responses of VLFS Based on Multi-Floating-Module Model Connected by Elastic Hinges | China Ocean Engineering (springer.com)
Please let me know.
Thank you!
