Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Floating point stirred tank using DPM › Reply To: Floating point stirred tank using DPM
May 8, 2024 at 9:24 am
OK. Do they need to be tracked with the fluid through the whole simulation time, or can you run them on a frozen flow field for post processing? Ie solver the flow and then run particles afterwards. This assumes the particles don't effect the fluid flow.Â
