Ansys Learning Forum › Forums › Discuss Simulation › Fluids › water inlet height-(water inlet boundary)-dose it represent a fixed height? › Reply To: water inlet height-(water inlet boundary)-dose it represent a fixed height?
May 8, 2024 at 8:00 am
walaakm10
thanks for your reply,
Okay, the case is that for this inlet (h), I draw it in geometry equal to 0.1m, but this is not the true case.
The true case is that there is a flood height of h, which increases from 0 to h along the simulation time (from time 0 to 30 minutes, for example).
From manual calculations for the flood at the inlet at each second, I know what the h and the velocity will be.
