Ansys Learning Forum Forums Discuss Simulation General Mechanical User Defined Result – CONTNMISC62 Reply To: User Defined Result – CONTNMISC62
Sampat Kumar
Hi
Did you perform the same model setup on your side as in the example in Ansys? It seems that it could be related to the contact issue. Which Ansys version are you using?
Best Regards,
Sampat
