Ansys Learning Forum Forums Discuss Simulation Fluids Pressure drop through a hole in a pipe Reply To: Pressure drop through a hole in a pipe
Dato
Hi Rob,
I have a question about the colormap legend of graphics. I'm using 2022R2 and legend pattern is shown below which is differnt from the ones in this discussion. Contour and variable name is above the legend and unit is located under the legend.
I want to set variable name and unit at same location without contour name displayed like this. How can I do it ?
Regards.
