Ansys Learning Forum Forums Installation and Licensing Ansys Products UDF: Segmentation fault when using F_AREA Reply To: UDF: Segmentation fault when using F_AREA
antosanf
Hi Rob,
Thank you for your answer. I was able to read the link you provided in Fluent.
Regarding the definition of A, I realized the following:
  • the UDF example you provided defines A as: real A[3]
  • my UDF defines it as: real NV_VEC(A)
I am not sure if this is the issue (would it make a difference?).
If that is indeed the issue, I replaced the definition to "real A[3]" but I again receive the segmentation fault error.
Thank you!
