Ansys Learning Forum Forums Discuss Simulation General Mechanical XFEM Initiation and Propagation Reply To: XFEM Initiation and Propagation
Ashish Khemka
Hi Prapatsorn,
I checked and the development of this ACT stopped. You will need to use command objects. Please see if following verification manuals help:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_vm/Hlp_V_VM193.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_vm/Hlp_V_VM287.html
In addition, please see if the following post helps:
/forum/forums/topic/having-problem-with-xfem-while-writing-apdl-commands-in-ansys-workbench/
You should take some care to specify the ETCON,OFF command to override Mechanical's default, which is different than MAPDL.
Ashish Khemka
