Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Floating point stirred tank using DPM › Reply To: Floating point stirred tank using DPM
May 7, 2024 at 4:04 pm
Thank you so much
Because I did an experiment to observe the movement of particles in the flow, the particles used in the experiment had a diameter of 3mm, so I had to set the size like that.
If I divided the mesh more coarsely, the mesh quality could not be guaranteed even though I tried many times. With the smallest mesh size of 1mm, can I accept the error and work with a particle with a diameter of 1mm?
