Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Why don’t the residuals converge? › Reply To: Why don’t the residuals converge?
May 7, 2024 at 1:34 pm
Plot contours of velocity around every 5 iterations for 50 iterations and look carefully at the output. Or put a couple of point monitors for velocity in the wake region. I suspect you've found a transient in the flow field from the way the residuals look, the monitors and contours will provide evidence of that.Â
