Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Floating point stirred tank using DPM › Reply To: Floating point stirred tank using DPM
May 7, 2024 at 1:16 pm
I'm not sure what the image is showing me, but unless the impellor tip speed is around 7m/s you have a problem.Â
Are you adding particles constantly, or only for a short period? How does the flow field look prior to it failing? Is the failure repeatable, or can you restart from a saved case & data and run beyond the initial failure time?Â
