Ansys Learning Forum Forums Discuss Simulation Fluids Simulating wind response of a floating body Reply To: Simulating wind response of a floating body
If you use 6DOF and tell it to react to the forces it will. Check the overset moving mesh example in the Fluent Help. It's a "something" falling off an airplane but other than water being a little denser it's much the same as you need.Â
