Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › corrupted double-linked list – bad termination › Reply To: corrupted double-linked list – bad termination
So, you can initialise & run locally but not on the cluster. If you pass case & data does that also fail? Check that any monitors are written to the local path and aren't trying to retain the path from the local machine. Otherwise, check in the logs for system errors - you may need to talk to your IT.
