Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Boundary Conditions for Stationary Fluid in which a solid body deforms › Reply To: Boundary Conditions for Stationary Fluid in which a solid body deforms
Adamya Dhaker
Hello!
Attached is the diagram of the domain. The curves body is the solid body, and the cube is the fluid domain. The curved body is supposed to be fixed at its lower (larger diameter) end and will deform through the fluid domain. You can think of it as an unfurling of rope/whip. Thank you!
