Ansys Learning Forum Forums Discuss Simulation Photonics How to Import Random Spectrum instead of AM1.5G Spectrum in Solar Genaration Reply To: How to Import Random Spectrum instead of AM1.5G Spectrum in Solar Genaration
Guilin Sun
In such case, the simulation source settings are the same.
In the analysis group, you will need to load/read the desired source data, and replace the solar spectrum. The rest is the same. I suggest to use matlabload:
matlabload - Script command
