Ansys Learning Forum Forums Discuss Simulation Fluids ansys aqwa error structure move to far Reply To: ansys aqwa error structure move to far
nhanani4
I already check using ansys aqwa gs.
I have few question.
I want to put hinge connector at multi floating structure.It is right the point coordinate that I put exactly side of module?
It look okay for me at workbench. but at ansys aqwa gs only see 1 side connector. the connector look inside the module. I want the connector only located  between two module. How to make the hinged connector put between two module? It look no gap connector.
If I put connector, the mooring attract more to right side before simulation run. What is the problem?
