Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Installing RSM Client on Windows Laptop to submit jobs to CycleCloud HPC › Reply To: Installing RSM Client on Windows Laptop to submit jobs to CycleCloud HPC
Divya Shree Surendran
Hi Dr. Roberto, no need for arccredentials - its only used if the scheduler is ARC
In your case its SLURM
Its the multiple IP address thats the issue.
Please edit Ans.RSM.Appsettings.config under the Install path of ANSYS on the cluster or you can follow this link to set RSM to point to the specific IP address of the headnode that can be reached by the clients.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/wb_rsm/wb_rsm_mult_nic.html
