Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Ansys 2023 – Material Designer – “MAPDL error” Reply To: Ansys 2023 – Material Designer – “MAPDL error”
Yingnan Wang
 I found another similar problem, which had been closed from a new reply. I attached the possible answer here.
The issue was that I tried the "-blas intel" on the MAPDL command line, but it showed this is not a recognized Begin command.  Can I get any suggestions based on this solution idea?
Thanks!
