Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Far-field planar mode projection › Reply To: Far-field planar mode projection
Guilin Sun
Negative sign is ok, as you can see from the definition https://optics.ansys.com/hc/en-us/articles/360034405254-overlap-Script-command it uses absolte value.
