Ansys Learning Forum Forums Discuss Simulation Preprocessing Cannot select mesh connection Reply To: Cannot select mesh connection
Asitang Lahurikar
Surface body meshes can be connected via mesh connections. Thus, to use that feature, surface bodies must be included in the model; otherwise, if the geometry only consists of solid bodies, the feature will remain disabled.
You may refer to the Ansys Help documentation to know more about the Mesh Connection method - Mesh Connections (ansys.com)
Thanks,
Asitang
