Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Peridynamics horizon in Impact Analysis › Reply To: Peridynamics horizon in Impact Analysis
Reno Genest
Hello Pau,
Why are you using DR=2 while the LS-DYNA User Manual Vol I recommends DR = 0.6 - 1.2 ?
The LS-DYNA solver will try to adjust DR so that the number of neighbors at a point is between 10 and 136. Search for Warning messages in the messag file similar to:
"Warning. The maximum neighbor number is 36
     the minimum neighbor number: 9
     which violates the threshold: 10~136 (Min~Max).
     The horizon size will be tuned, and new search starts"
I would pick a value of DR so that the number of neighbors at a point is between 10 and 136.
Let me know if this helps.
Reno.
