Ansys Learning Forum Forums Discuss Simulation Photonics Far-field planar mode projection Reply To: Far-field planar mode projection
Guilin Sun
A1: no requirement for normalization;
A2: there are interpolation errors and overlap is approximation for coupling! the best way to do coupling is using FDTD and check the S parameter result.Â
