Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Far-field planar mode projection › Reply To: Far-field planar mode projection
eugenio.digaetano
Thanks Guilin, this is exactly what I meant to do, I was wondering how to optimise the two modes position in FDTD but I found an easy solution. I just simulate the mode profile at different distances from the facet in FDTD using several monitors and export the results with savedcard function. I then import it in MODE and use the standard Overlap Analysis either manually and by script with the mode at facet from the second waveguide.
