Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Solving an input file using command line › Reply To: Solving an input file using command line
May 2, 2024 at 2:31 pm
Andrew
No, the input file should be considered version specific. That's not to say that it (file from v22) will not solve (on solver v15); it depends on if you are using a feature/function that has changed or not. Or even using a feature/function in v22 that did not even exist at v15. The Help has Release Notes for each version that goes into details of the changes. Â
