Ansys Learning Forum Forums Discuss Simulation General Mechanical Showing same value of equivalent peak stress as the specified yield stress Reply To: Showing same value of equivalent peak stress as the specified yield stress
Armin Abedini
Hi Farhana,
For the Bilinear Isotropic Hardening model, the entry “tangent modulus” specifies how your material work hardens.
The tangent modulus in your model is significantly small, meaning that the material’s behavior is similar to a perfect plastic material with almost no increase in the stress with plastic deformation. This explains what you observed in the results. Please ensure that this is the expected behavior for your specific material and if not, adjust this parameter accordingly.
