Ansys Learning Forum Forums Discuss Simulation General Mechanical Solving an input file using command line Reply To: Solving an input file using command line
Andrew Skocz
Hi Mike, thanks very much for a quick reply.
In WB, I am using standard mechanical with some contacts and joints. It is all static.
Do you know if the written input file is version agnostic? I am using WB 2022 but also have a WB 2015 with some HPC licenses that I'd like to use but not sure if 2015 would solve the input file exported from 2022.
