Ansys Learning Forum Forums Discuss Simulation Fluids Non-conformal Mesh: Boundarie is automaticly set to wall instead of internal Reply To: Non-conformal Mesh: Boundarie is automaticly set to wall instead of internal
Ivosp
So the settings I used for describing the geometry are (the ones I changed is written in bold)
  • Geometry Type -> The geometry consists of both fluid and solid regions and/or voids
  • Will you cap openings and extract fluid regions? -> No
  • Change all fluid-fluid boundary types from 'wall' to 'internal'? -> Yes
  • Do you want to apply Share Topology? --> No
  • Enable Multizone Meshing? -> No
The boundary types I used for the touching spherical surfaces are internal.
I didn't change the rest of the settings.
