Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Straight segment becomes warped while sweeping on SpaceClaim 24R1 (student) › Reply To: Straight segment becomes warped while sweeping on SpaceClaim 24R1 (student)
Atharv Joshi
Hi Alex,
You can refer to the above post by Peter for creating bend pipe section.
Once you create the sketch, circular surface you can use the Sweep options from the Pull Tool.
Select the circular surface, activate sweep options, double click on the path to select the loop and enter.
Let me know if you face any issue.
Thanks and Regards
Atharv
