Ansys Learning Forum Forums Discuss Simulation General Mechanical Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent Reply To: Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent
Foo Sin Khai
Hi there, can i know why this happen, is it normal, why the value heat absorbed at hot surface is same as the heat released at the cold surface but opposite sign?
