Ansys Learning Forum Forums Discuss Simulation General Mechanical MPC Joints Shared Between Bodies Reply To: MPC Joints Shared Between Bodies
matt
Here is the structure shown as shells and lines.
Thick shells and beams are shown here.
The problem occurs at several locations in the model, but for this discussion, we'll just focus on a few.
I'll provide a few examples for our discussion.  Here is a table depicting the connections shown below.  17 and 23 interact.  37, 41, 46, 47, 51, and 52 interact.
Joint NameRef. ScopeRef. Mobile
17Vertex 1Vertices 2,3
23Edges 6,7,8Faces 1,2,3,4,5
37Vertex 1Vertex 2
41Vertex 1Vertex 2
46Vertex 1Vertex 2
47Edges 1,2,3Edges 4,5,6
51Vertex 1Vertex 2
52Face 1Face 2
Joints 17 and 23 conflict and are shown in the following images.
Joints 37, 41, 46, 47, 51, and 52 conflict and are shown in the following images.
As you can see, the connections are quite tangled.  But this is how things are connected in reality.  I need to come up with an alternative method to connect the pieces.  Can you elaborate on "connection body with three legs?"  Is this a set of small lines that are joined with Shared Topology, and have separate joints at each end for connection to the assembly?
