Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Slice geometry in .stl file › Reply To: Slice geometry in .stl file
peteroznewman
Open the .stl file in SpaceClaim.  On the Design Tab, select three vertices (or one facet) and click the Plane tool.  You can also move the Plane around using the Move tool  On the Facets tab,use the Split tool.
