Ansys Learning Forum › Forums › Discuss Simulation › Fluids › using a solution as a starting point › Reply To: using a solution as a starting point
1900307
thanks rob, just final question, in the 1st & the 2nd question would i need to intialize and if so does that cancel what i did.
i mean if i changed the vector would the i need to start, or could i use the niterpolate files.
