Ansys Learning Forum › Forums › Discuss Simulation › Fluids › using a solution as a starting point › Reply To: using a solution as a starting point
Assuming you're not in Workbench. You can continue a Fluent run having changed something in the solver. So if you change the far field vector just hit iterate once you've done it. You need to save the case & data files for later post processing though.
Have a look at mesh refinement (adaption) and interpolation files.
