Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Problem with Shared Topology or contacts in a Lattice Communication Tower › Reply To: Problem with Shared Topology or contacts in a Lattice Communication Tower
I did it. It worked. But the frequency is still Zero(0). How to get Frequency >1 as its required. And Also, I cant calculate the Beam results due to errors.
Static Structural Errors :
1. An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Please see the Troubleshooting section of the Help System for more information.
2. An internal solution magnitude limit was exceeded. (Node Number 1, Body Level 1.1, DOF UX) Please check your Environment for inappropriate load values or insufficient supports. You may select the offending object and/or geometry via RMB on this warning in the Messages window. Please see the Troubleshooting section of the Help System for more information.
Warnings :
- Solver pivot warnings or errors have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully.
- Line bodies with type set to Link/Truss or Cable may not be able to solve if Large Deflection is turned off in the Analysis Settings for the model. (I turned this ON)
