Ansys Learning Forum Forums Installation and Licensing Ansys Products Installing RSM Client on Windows Laptop to submit jobs to CycleCloud HPC Reply To: Installing RSM Client on Windows Laptop to submit jobs to CycleCloud HPC
Divya Shree Surendran
Hi Dr. Roberto, WinSCP or Filezilla are secure copy clients to copy your files via SSH - SCP into the RSM Staging directory on the cluster. This is outside RSM and hence you can say External File transfer for File management and use the clients for File copy.
If that is not preferred you can setup a Samba or CIFS share that enables your Windows clients to be mapped with the Staging directory
