Ansys Learning Forum › Forums › Discuss Simulation › Fluids › What are the post processing tricks for water surface? › Reply To: What are the post processing tricks for water surface?
April 30, 2024 at 10:52 am
Please can you plot the mesh surface with edges on? I suspect the difference is mesh resolution on the free surface. You can see the local refinement (adaption) on the side walls in the top image.
