Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Import CAD with solid and fluid body to Rocky? › Reply To: Import CAD with solid and fluid body to Rocky?
April 30, 2024 at 10:40 am
First of all it's generally easier to run Rocky & Fluent coupling outside of Workbench. You may then find that once you do connect Fluent into Rocky that you can remove all of the solid surfaces just leaving those you need for the fluid region. However, before going much further reviewing the Rocky content in Learning and from Help would be a good idea: that includes tutorials.Â
