Ansys Learning Forum Forums Installation and Licensing Ansys Products Analysis systems missing in workbench toolbox Reply To: Analysis systems missing in workbench toolbox
spankore
Hello Jeorg,
Greetings.
Can you please try the below workaround on client machine and let me know if that helps?
1. Close all the Ansys applications before trying the below suggestion step by step. Can you please try adding the below timeout features in the ansyslmd.ini file –
Go to C:\Program Files\ANSYS Inc\Shared Files\Licensing directory, copy the ansyslmd.ini file to the desktop location.
Open the ansyslmd.ini file using Notepad and add the following lines after other lines.
ANSYSLI_FNP_IP_ENV=1
ANSYSLI_TIMEOUT_FLEXLM=20
ANSYSLI_FLEXLM_TIMEOUT_ENV=20000000
ANSYSCL_TIMEOUT_CONNECT=60
ANSYSCL_TIMEOUT_RESPONSE=300
Once you add the lines, click Save As > ensure that the save as file type is ‘all files’.
Once the file is saved, please replace the old ansyslmd.ini file using the newly created one.
Also set the following Environment Variable –
Go to START > ‘Edit the System Environment Variables’ > click Environment Variables.
2. Under the System Variables, please click NEW and create a new variable.
Variable Name – FLEXLM_TIMEOUT
Variable Value – 50000000
Save it.
3. Open the HOSTS file on client machine and add the license server name and IP of the license server in that hosts file.
Path: C:\Windows\system32\drivers\etc\hosts file “ as per the following format in your client machine :
Example:
IP address                                    Hostname of server
IP                                                    License_server_name               //IP address of server and name. (Make sure you get the license server IP from your IT team/who handles the license server)
Like in last line of hosts file just add :
4.  Config File Reset -
Now open a file explorer and type %appdata% in the address bar. Locate the Ansys folder and rename it to Ansys.old.
Now try launching Ansys WB application to see if it loads without any issue.
About the Spaceclaim issue :
Open the Spaceclaim from start meun -- Once you receive the error click OK with that error message -- There is one popup comes -- select the alternate license from the dropdown and select the Checkbox as well.
After that the spaceclaim application will work
Thank you.
