Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › How to get instersection Points made by two line bodies going through each other › Reply To: How to get instersection Points made by two line bodies going through each other
mjmiddle
It sounds like you are moving on to different topics, so you should submit a new post(s). If you have rigid body motion, make sure your beams are connected either as a shared multibody part in DM or joints or MPC contacts in Mechanical.
