Ansys Learning Forum Forums Discuss Simulation Embedded Software How to change the return type of the created function operator? Reply To: How to change the return type of the created function operator?
Romain Andrieux
To clarify, are you looking to:
  • Integrate code generated from SCADE Suite ?
  • Integrate code generated from SCADE Display ?
  • Integrate imported code into SCADE Suite ?
For code generated from SCADE Suite, the output is either generated as return or passed by argument depending on multiple conditions.
It is returned when the followings are met:
  • The operator is declared as a function,
  • It has only one output,
  • If it is a root operator, then the code generation option ‘Separate I/Os’ must be set for this operator.
Thanks
Romain
