Ansys Learning Forum › Forums › Discuss Simulation › Fluids › New Material properties, Latent Heat of Vaporization › Reply To: New Material properties, Latent Heat of Vaporization
SRP
When defining properties for liquid water and vapor water under vacuum conditions in Ansys Fluent, you may need to manually input the properties if they are not available in the Fluent database.you can create a new materials database, copy materials to database.
You can check fluent user's guide for more details: 8.1. Defining Materials (ansys.com)
Hope this helps you.
