Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent › Reply To: Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent
Foo Sin Khai
Hi, thank you for your reply.
Is this what you mean draw one more geometry for thermoelectric generator layer like i show in the pic below and then run it again in fluent together with the thermoelectric generator layer to capture the temperature profile. can i do this way?
