Ansys Learning Forum Forums Discuss Simulation General Mechanical Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent Reply To: Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent
Erik Kostson
Hi
You should be able to drag and drop from a Fluent system (Solution cell) to the Thermal Electric System (Set up cell) say in 2023 R2.
In that system you can then add: Imported Load (Fluids Results File) and a temperature load import.
See here for this workflow - it is for steady state but should be similar for thermal electric.
Otherwise external data can be used.
Erik
