Ansys Learning Forum Forums Discuss Simulation 3D Design How to get instersection Points made by two line bodies going through each other Reply To: How to get instersection Points made by two line bodies going through each other
Suhi Suhaas
Errors :
1. An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Please see the Troubleshooting section of the Help System for more information.
2. An internal solution magnitude limit was exceeded. (Node Number 113, Body Level 3.6, DOF UX) Please check your Environment for inappropriate load values or insufficient supports.  You may select the offending object and/or geometry via RMB on this warning in the Messages window.  Please see the Troubleshooting section of the Help System for more information.
Warnings :
1. Solver pivot warnings or errors have been encountered during the solution.  This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues.  Check results carefully.
2. Line bodies with type set to Link/Truss or Cable may not be able to solve if Large Deflection is turned off in the Analysis Settings for the model.
3. One or more objects may have lost some scoping attachments during the geometry update. You can identify these tree objects by activating the Scoping Wizard in the Selection Toolbar, or by filtering the tree using the Scoping option set to Partial.
By the way, thanks for being patient with me. I have these issues and been struggling since weeks. Can you help me how to solve these errors regarding Truss elements.
