Ansys Learning Forum Forums Discuss Simulation LS Dyna SALE Sensor to Capture Element Pressure History Reply To: SALE Sensor to Capture Element Pressure History
Ian Do
[Q1] select node set or other sets from S-ALE mesh
[A1] I am sorry this is being developed. Currently we do not have an easy way to do this selection. If you really need this, I will write out a procedure to get it, but it is tedious!
[Q2] Visualize vol-filling on the fly
[A2] This is also another developmental request I have submitted to our LSPP team. I hope that they will have time to implement this very useful feature also. Currently, the way to check is to run the deck with ncycle=1 on the command line ==> then postprocess d3plot. SELPAR ==> NONE==> FLUID ==> select each AMMG to see the AMMG filling.
