Ansys Learning Forum Forums Discuss Simulation 3D Design How to get instersection Points made by two line bodies going through each other Reply To: How to get instersection Points made by two line bodies going through each other
Suhi Suhaas
Sorry. Now I remember.
This is the plan actually. And I had to project the points onto the main members or main legs. After, creating those projection points, I went on to create X bracings or Cross Bracings. After this step, I had to create horizontal bracings. To create them I took half of each length, for example, 4000mm/2 = 2000mm, and created points manually to project onto the main member. Now, after projection and I created lines using “LINES FROM POINTS” to create HORIZONTAL bracings. Then, those intersection points of all bracings were not created automatically. I used Projection tool to create those points.
