Ansys Learning Forum Forums Discuss Simulation Fluids How to reduce number of Cells in fluent meshing Reply To: How to reduce number of Cells in fluent meshing
Not meshing the casing may well help. Have a look at Fluent's thin wall options.
Depending on how much RAM you have you may be causing the hardware to page to disc if the RAM needed is higher than what is available. Then there are model specific effects.
