Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Vial temperature simulation › Reply To: Vial temperature simulation
April 29, 2024 at 1:33 pm
Wall temperature and static temperature aren't the same, check the definitions in the manual  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v222/en/flu_ug/flu_ug_fvdefs.htmlÂ
The last image suggests that you need to check the pressure boundary reverse flow temperature.Â
